Foreshortened dimensions
jseifeddine
jseifeddine
Hey all. I'm trying to figure out how to foreshorten a dimension for a detailed view? I want the diameter of this groove because it's difficult to see in a regular view. Jogged radius doesn't work here since Fusion sees this as a straight edge. I understand that Fusion doesn't support foreshortened dimensions, there must be some work around to this...? Thanks!
James
jhackney1972
If you are willing to work at it, you can use the Create Sketch command in the drawing workspace to create the geometry needed and the text command to add the dimension.
John Hackney, Retired
jseifeddine
Hi John. Thanks. Was hoping there was a less manual way, but it should do for now.
