Font problems
Font problems
Message 1 of 15
Font problems
Hey Questions....
I have been reading forms on importing fonts to Fusion.... I have downloaded and installed many fonts that are "fancy" cursive and really any font. I download them and then restart my computer. When I load fusion back up they are in the font list but they don't display as the font type just as like times new roman. Has anyone had this issue? The fonts work in word and everywhere else.
Replies (14)
Message 2 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 community!
I found some font-related forum threads as below. Please check the below pages. I hope they are helpful!
http://forums.autodesk.com/t5/design-validate-document/import-text-font/m-p/5766718#M30286
http://forums.autodesk.com/t5/design-validate-document/newly-installed-fonts-doesnt-show/m-p/6249002...
http://forums.autodesk.com/t5/design-validate-document/installed-font-not-showing-in-fusion/m-p/6366...
** Fusion only supports TTF fonts for modeling operations. If you can share TTF font, we will be able to investigate closer.
    If it is a symbolic font, there may be some limitations.  Fusion purposely excludes symbolic fonts - see this thread for more detail.
If you have any questions, please let me know.
Thanks!
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 15
rtepas
hi, i wrote a response, it seems to be gone, so once again.
I have a font that worked fine, now for, i think a few month, it does not work anymore. Shows up, when i select it than it is a default font, not the looks that belong to the font type.
.ttf attached
ps: now i know why my post is gone, if i add a .ttf it does not post,  .zip works fine
Message 4 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @rtepas,
Thank you for your response!
Sorry to hear that.  I will check this and update this thread once I have something to share!
I thank you again for your patience.
Kanehiko SAITO
Message 5 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @rtepas,
Thank you for sharing the font file!
As I tested this on my end,  I found that the font did not show the looks in the Sketch mode although the font type was listed in the Text command window.  However, it showed the looks in the Drawing mode.  Did this font work fine in the Sketch mode as well?
Hopefully this helps.
If you have any questions, please let me know and I'm happy to help!
Thanks.
Kanehiko SAITO
Message 6 of 15
rtepas
hi, thanks
drawing mode, can you explain an bit more ?
when i make a sketch i looked fine and when i stop sketching because i was
done it also looked fine.
see for instance this: https://www.thingiverse.com/thing:2697892
Richard
Message 7 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @rtepas,
Thank you for your reply!
The drawing mode is a workspace to create a 2D drawing from 3D model.  In the workspace, I was able to create texts using "Corrodo Normal" as below screenshot.
If you have a design file using this font in the sketch, would you mind sharing the file with me so that I can take a closer look at this with my colleagues?  If it is okay with you, can you please share a public link to the file, by posting in this thread or sending me (kanehiko.saito@autodesk.com)?
Thanks.
Kanehiko SAITO
Message 8 of 15
rtepas
here is the public link https://a360.co/2P0JFZN
thanks !
Richard
ps in 2D drawing i do net get the font as it should be
Message 9 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @rtepas,
Thank you for sharing the design!
I was unable to find text entities (using the Text command in Sketch).  The text "VR6" in sketch seemed to be creating by importing or creating in "Sketch 1" of the design file.  I thought you tried to create "VR6" using the Text command with the "Corrado Normal" font - if I misunderstood this, I would appreciate your sharing a bit more detail about this!
Can you please let me know which "Sketch" you created in browser or timeline?
Thanks.
Kanehiko SAITO
Message 10 of 15
rtepas
hi,
this is strange, normally when i have a sketch with text, i can edit the
sketch and inside this edit, edit text.
tryed several objects where i used the Corrado font, edit text is not
availeble in those sketches anymore ??!!
Message 11 of 15
saito.kh
Autodesk Support
Autodesk Support
Hi @rtepas,
I've logged the behavior (regarding Corrado font worked fine in the previous versions of Fusion) with our development team for the further investigation. (internal ID: FUS-42810)  I will get back here once I have something to share!  Thank you for your patience.
At this time using a vector graphical editor such as Inkscape, I would create texts in the font type and converted to outline; then export in SVG to Fusion - the below link would help how to do this:
Getting any Text and SVG file into Fusion 360 to work
Thanks.
Kanehiko SAITO
Message 12 of 15
rtepas
thanks for this tip !
Message 13 of 15
textandfontz
Community Visitor
Community Visitor
Hi, One the above link is best for me:
http://forums.autodesk.com/t5/design-validate-document/import-text-font-pubg/
Can anyone guide me about this or not? Thanks
Message 14 of 15
g-andresen
If you tell us what you are specifically concerned about, we can say something about it.
günther
Message 15 of 15
jhackney1972
If you are saying your have a Font file, probably TTF type, that does not show up in Fusion 360 text list after adding it to Windows, the reason may be that Fusion works with OTF fonts better.  Use one of the online font conversion sites to change the font to OTF.  When installing, make sure Fusion 360 is not running.
John Hackney, Retired
