Flat pattern
Flat pattern
jonas.holmstedt
Observer Observer
Message 1 of 10
Flat pattern
jonas.holmstedt
Observer
Observer
How can i make this to a flat pattern?
Replies (9)
Message 2 of 10
davebYYPCU
Is it Sheet Matal part?
Needs to have edges perpendicular to faces.
Might help....
Message 3 of 10
jonas.holmstedt
Observer
Observer
It`s a body and i cant convert it to sheetmetal.
Message 4 of 10
davebYYPCU
Yep, looks like it was made with Loft.
If not converting, will be the non square edge (right side of pic) or not constant thickness, holding you back.
Might help....
Message 5 of 10
g-andresen
you need a flat face
günther
Message 6 of 10
TheCADWhisperer
Message 7 of 10
jonas.holmstedt
Observer
Observer
Message 8 of 10
jonas.holmstedt
Observer
Observer
Message 9 of 10
g-andresen
1. for conversion into sheet metal part, the thickness of the component must be constant. This is not the case here.
2. in addition, there must be a flat surface for unfolding, which can be added additively perpendicular to a flat edge.
günther
Message 10 of 10
TheCADWhisperer
@jonas.holmstedt
Why do you have Capture Design History turned off?
Turn history back on
remodel the part from scratch with history and then re-attach the new attempt here.
