Flat pattern doesn't work regardless of object complexity (Fusion 2.0.10564, July 2021 Update)
mainarx
mainarx
Hello. I found myself stuck unfolding any geometry. Sometimes it works partly - no bend lines appear, but in most of cases I get warning like this one:
The geometry itself is very simple. Is there something I'm doing wrong or this is a bug?
Thank you.
HughesTooling
You can fix the error if you override the 3 corner bend relief radius. Note you will only see the modification on the flat pattern. See Inventor help for a bit more info.
Mark Hughes
Owner, Hughes Tooling
mainarx
Thank you, that did it. I wish that error warning and help page were more informative though.
