Flare around cylinders base
oxicottin
Message 1 of 10
oxicottin
Hello, I'm new to drawling like this so please bare with me 😋.  I need to create a flare around 2 cylinders bottoms. They  intersects with a second cylinder, the image is attached. I cant for the life of me figure out how to do that?
here is my project:
https://a360.co/3orMdmd
Thanks chad
Replies (9)
Message 2 of 10
jhackney1972
You show a link to your project but you forgot to allow download.
John Hackney, Retired
Message 3 of 10
oxicottin
It wont let me without a subscription.... Which I have the free version not the paid so I think im outa luck there!
I did doenload a stl. and attached though.
Message 4 of 10
jhackney1972
If that is the case, you can always share your Fusion 360 model by opening it up, go to the File menu, select Export and save it to your hard drive.  Then you can attach it to the Attachment section of any forum post.
Message 5 of 10
seth.madore
@jhackney1972  yeah, the Personal Entitlement is restricted in this department. I've stopped asking for the A360 link and just went straight to requesting the .f3s/.f3z model
Seth Madore
Message 6 of 10
oxicottin
@jhackney1972  @seth.madore
Ok I'm sorry guys/gals im learning not only 356 im learning how to post.... I needed to do two things left and have no idea on how to do either.  Is this the correct forum to post questions?
1) I need to create a "Flare" around cylinder(s) ends.
2) I need to widen the hole in the top like in the image.
Message 7 of 10
jhackney1972
This is the best I can do with your model.  I have no idea how to get a flare around the side-to-main pipe due to the intersection to the top connection body.  You did not give any dimensions for the top cutout so I just used something that looked good.  My attempt is attached.
Message 8 of 10
oxicottin
@jhackney1972  Would you be able to do a screencast of how you did the hole?  Thanks!!
Message 9 of 10
jhackney1972
Here you go.
Message 10 of 10
oxicottin
@jhackney1972  Than you so much now i can play around with it!
