First Time Save in New Project Won't Work
- Mute
- Permalink
- Report
When creating a New Project folder by way of saving a file for the first time (which is an option in the pop up window and I'm sure a fairly typical workflow) Fusion will not let you save the file into this project. All other Projects remain accessible and you instead need to cancel the saving of this file and click Save again, the new project will then be available. Screencast below showing me clicking it a number of times after finished creatingthe Project Folder:
Failing that you can save it into a different Project Folder and then move it... except that I found that doesn't seem to work either as no other Project Folder is selectable, instead it appears as though the only option is to save it in a sub-folder to the Project that you are already working in. So instead you will need to Copy this file to the correct Project Folder after having saved it in the wrong one and then delete the redundant copy...see Screencast below as well:
David
