First startup hung on "Setting up Fusion"
jlparsons_ca
Observer Observer
jlparsons_ca
Observer
Observer
Hi all, complete newbie to Fusion here, I've just installed the free personal use version to begin the process of learning to use it.  When I run Fusion it has me sign in then gets to the "Setting up Fusion" section with the spinning wheel indicating something is loading/processing, then hangs there indefinitely.  Any ideas how to fix this?  Running on a Windows 10 VM client within Linux Mint.
RajkumarIlanchelian
@jlparsons_ca Can you try to login to https://login.autodesk360.com/login and see if that completes your set up?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
jlparsons_ca
Observer
Observer
Ok I just tried to sign in, it's created a hub and now it's downloading Desktop Connector, I assume the lack of these things might be the problem?
RajkumarIlanchelian
@jlparsons_ca @Desktop connector is not a requirement. Is your Fusion application working now?
Autodesk Fusion
Join Fusion Insider
jlparsons_ca
Observer
Observer
Yes it all seems to be working now oddly, the only difference is that I created a Hub and installed desktop connector
RajkumarIlanchelian
@jlparsons_ca Creating the hub was the issue early on. Once you used the web to create the hub then everything should flow well and it looks like it is.
Autodesk Fusion
Join Fusion Insider
jlparsons_ca
Observer
Observer
Seems to all be working correctly now, many thanks!
