Finishing path issue
tsimsTX256
tsimsTX256
im posting a snip of the problem, you can just see where the tool randomly shoots of into the material. this does not show up on the simulation. but it did scrap a mold that i have been running for 6 hrs. this only happened on two cavities and none of the others. any explanationfusion problem.JPG on why this is happening?
karina.harper
Autodesk Support
Autodesk Support
Hi @tsimsTX256
If you share the file, we might be able to help you out!
Karina
tsimsTX256
https://a360.co/2TQnPiM
this is the link it gives me to share the file. I'm still getting used to the forum. let me know if it works
tsimsTX256
I believe I have fixed the issue, but I don't understand it. I had to bring the tolerance on the contour down from .0004 to .0001. Why would such a small amount make that big of a problem? Is there a rule of thumb on setting the tolerance?
karina.harper
Autodesk Support
Autodesk Support
Hi @tsimsTX256
I took a look at the file, and the basic answer is that there is an issue in smoothing where in certain cases it collides into the material without warning. The workaround is to disable smoothing or adjust the tolerance (like you did) until it works correctly.
This has been logged with the team and it has quite a bit of attention. (Internal CAM-13397)
Cheers,
Karina
