Message 1 of 14
- Mute
- Permalink
- Report
HI there, i'm totally freaking out since i cannot open any version of the main project i'm currently working on. EVERYTHING is in that file, it would set me back weeks if i lost all versions of thsi. I had saved copies of the file as i was buuidling but all these can also not beopened any more. I'm not trying out all versions and files since i fear that trying to open them corrupts them,
I can't share the file publicly and can't find an option to contact support directly. Could someone from autodesk support help out please. I have not found a solution in the forums. I have tried the webviewer but it will come up empty or with only a few objects.
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
