Fastener appearance incorrect in final renders
alyssa.turnerTMP3W
alyssa.turnerTMP3W
Fasteners aren't appearing correctly in renders. They're correct in the render environment and in-canvas renders, but when I do a proper render they are the wrong material (see pictures, the bolts are supposed to be black). This happens in both cloud renders and local renders.
CGBenner
@alyssa.turnerTMP3W
Hello and welcome!
Can you verify if the lighting settings are the same in all scenarios?
Chris Benner
alyssa.turnerTMP3W
Yes, everything is the exact same. The bolts should be black steel.
TrippyLighting
Can you share the model?
alyssa.turnerTMP3W
Not on a public forum no - NDAs and such. Should be fairly simple to replicate no?
Edit: Here's a model of just a fastener that is having the same issue: https://a360.co/48Uxc2z. Not sure how sharing will work exactly with the new fasteners feature though.
Edit 2: Yeah, looks like when sharing it also has this appearance issue, yet here it is in my fusion team correctly appearing as black like the name says it should be:
TrippyLighting
When I apply a black finish to the screw in the file named "Bolt appearance issue" it takes it and renders correctly.
Changes to the file " Hexagon Socket ...." do not propagate through to the assembly.
I am assuming this has to do with the fact that this is a part from the Fastener library.
That could be a bug.
alyssa.turnerTMP3W
So is this thread all  that's needed for them to work on the bug?
