Fanuc posting G68.2 error
8waystomake
8waystomake
Using the Fanuc G91 generic post,  machine is a yama-seiki with fanuc OI-M control.   Post is generating a G68.2 (multi axis?) so i edited the post to false under multiaxis.  Now error saying G54 not specified when i repost, plane, axis etc is all specified and correct in model & setup agrees.  Where should i look from here.
seth.madore
To be clear; you are using a 3 axis machine, correct?
Could you share your file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Also, are you using the most recent Fanuc(G91) post processor (should be #43888)
Seth Madore
8waystomake
Yes, 3 Axis machine.  We did figure it out.  We had to delete the tool path then re add it.  Fusion was hung up and reading the unedited post that read multiaxis = true , even after we had changed it to false.
