failure in assembly plans
ingenieria3ZTWM2
ingenieria3ZTWM2
When making the drawings of an assembly, when I disable the visibility of several parts to make individual plans of each part, a problem is generated in the view, since the shadow of the part that I deactivated remains. How can I fix it?
jhackney1972
Please attach your assembly model, not drawing, so the Forum users can take a look.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
ingenieria3ZTWM2
yes
