Face not extruding all the way
navpat
navpat
Hi all,
I'm trying to extrude a face (by pressing q and e) 18mm outward but it only goes to 10 mm. The face turns red after that. I tried making another circle and tried extruding that further but it only goes to 10 mm too. Any suggestions?
Please take a look at my screen below:
jhackney1972
Look in your Browser, notice you have an Analysis folder containing a, maybe more, Sectional Analysis.  Open it and turn off the active sectional analysis and it will work fine.
John Hackney, Retired
jeff_strater
you have a Section Analysis enabled on this design.  The Extrude is fine, it is just extending beyond the cutting plane of the section.  Turn off the analysis, and you will see that your geometry is fine.
Jeff Strater
Engineering Director
navpat
yes, it worked! thank you
navpat
it worked, thank you!
