F3Z Export no longer works with some files
MaxFries
MaxFries
I have the problem that with some files (however, all are very similar and are partly former f3z exports of each other) the f3z export no longer works. Even a version that was exported a few weeks ago, now always throws an error message when exporting. In the Autodesk forum I found a similar question about the problem and therefore removed any special characters in the file names, because they seem to cause problems.
The error message for me is: Fusion Team Error Message Max attempts with no progress.
Are there other possibilities, e.g. a console with which one could limit the problem more exactly?
greetings Max
bharathkumaran26
Hi @MaxFries
Please refer the link below. You may find the answer for your question. Follow the steps given in the below link and try exporting the file once again:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/No-...
If you find this solution useful, Kindly click on 'Accept Solution'.
Thanks & Regards
Bharath R K
MaxFries
Thanks for the suggestion. I already tried to export by using the webbrowser multiple times, but I did not get any email after 2 days. When I try it with other files, the email with a download link arrives within a few minutes.
I thought there is a problem with some component of the assembly, but I have exported every file included in the assembly, without any problems. The only file that isn't able to export is the assembly itself. So I am absolutely clueless to what the problem could be. The only thing I could imagine would be some kind of size limitation. Two of the included components are rather large for my feeling, each being around 130MB without having much in them. I downloaded them from a trustable source on the internet, but earlier sucessful exports of the same assembly also included those files.  That's why some kind of console would be amazing to see, where the export fails.
MaxFries
I found the issue. I disabled "capture history" of those two large files, what brought them down to 40MB combined. Afterwards the export worked just fine. I guess there is an overall size limit for exports of around 300MB. Because I added a few features after my last export, the new file aparently exceeded this limit.
