F360 in a Browser
F360 in a Browser
Miha-M
Message 1 of 10
F360 in a Browser
Miha-M
Hi
So in out company he have an account A that is the owner of the F360 licenses . This are then assigned to accounts B and C. Account A does not actually use any product it is just the owner of the licenses (company account if you want).
Now one day I (account B) wanted to just look up and edit a model from home laptop. I thought well I can just log in, and open it in a browser since F360 has a browser version. But when doing that I got a message " Autodesk Education or Commercial Account Required" ??!  So why cant I use F360 in a browser if I have commercial f360 license assigned to me?
Replies (9)
Message 2 of 10
HughesTooling
Was this the webpage you used?
https://fusion.online.autodesk.com/
Only other thought, where you signed in before going to that page? Might want to sign in to your hub first.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
Miha-M
Yes Im logged in to my Autodesk account Dashboard now. Page where i can manage project, view files,. Is this the same as "Hub"? And when opening your link I get the same message.
Message 4 of 10
HughesTooling
I would like to tag someone in from Autodesk but it looks like the little elves are busy breaking the forum software again! I'll try again later.
Mark Hughes
Message 5 of 10
JDMather
@Miha-M
I have not used browser version - but there might be another way.
Are you aware that you can install Fusion 360 anywhere you need it?
If your personal computer has the specs to run Fusion, you can legally install.
The license is tied to login, not to the actual install.
Message 6 of 10
Miha-M
I m aware of that. This is what I end up doing although is my wife's laptop actually and i really dont like installing my software on it to use it like 5 times year.
It is just that browser based f 360 is so convenient for this occasions.
Message 7 of 10
HughesTooling
@Phil.E  Would you have any insight on the problem from the first post?
Thanks Mark
Mark Hughes
Message 8 of 10
Phil.E
This might be a simple issue of cached information. First try restarting the computer if that hasn't been tried yet. If it still fails, please screen-shot the message you are getting and post here.
Another thing you could try is opening an incognito window and logging into online Fusion there.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 9 of 10
Miha-M
Incognito mode does not work.
Also,  wife's laptop at home, which never had Autodesk product installed before, and workstation at work lead me to the same message as on attached picture.
Message 10 of 10
Miha-M
I see the problem has been solved and I can access f360 in a browser.
Thank you
