F360 drawing module keeps crashing. OSX
niklas
niklas
Hi guys,
I'm a big fan of F360, and it has worked pretty good until now. I'm doing some drawings for new parts, but the drawing module keeps crashing and crashing. Sometimes it crashes when I try to load a drawing, sometimes it crashes when I want to set a dimension, and sometimes during export (pdf). It has crashed more than 20 times today, and it's getting very frustrating since I've deadlines to follow.
Can you please help me out? What can I do?
I have the latest release
OSX 10.15.5
rMBP early 2017
ryan_d_rivas3030
Im having the same issue. I cant even open a drawing created before the update without the drawing workspace/client crashing. EXTREMELY frustrating as I need get some work submitted for approvals.
leowarren34
Hi @niklas,
Are you getting any error codes?
Can you upload your crash logs? https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I also found this solve thread which may help you: https://forums.autodesk.com/t5/fusion-360-support/drawing-keeps-crashing/td-p/9081692
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
ryan_d_rivas3030
I actually just performed a "clean install" per the steps in the below link and it seemingly fixed my problem. I haven't had a crash as of yet, but I really only needed to re-export an update of 1 multi-page print. So very limited sample size, but I think it works.
Here are the steps below.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
sdelquin
Same problem here! Drawings are almost unusable. It freezes randomly. Sometimes when I zoom, sometimes when I place a view, sometimes when I put a dimension and so on.
I also posted this situation here:
https://forums.autodesk.com/t5/fusion-360-support/drawing-keeps-crashing/m-p/9655358/highlight/true#...
With the previous release of Fusion 360 I didn't have these behaviour.
I tried the clean installation but the freezing problems stay. It is so hard that I need to restart my computer.
MAC OS MOJAVE
MacBook Pro (Retina 13 inches, first 2015)
Autodesk Fusion 360 v2.0.8624
Any help??
sdelquin
Apparently the issues were related to a drivers' update:
https://mrmacintosh.com/2020-002-update-causes-some-macs-to-freeze-when-using-hw-accelerated-video/
I installed the 2020-004 Security Updates for macOS Mojave and, since that, everything works fine on Drawings.
Sergio.
