Extrusion Tool not displaying entry fields
LaleveeJT
LaleveeJT
As of yesterday's update when using the extrusion tool I cannot enter a distance or select an object for extrude to object. Switching between the two brings the field boxes back, but they do not show up initially. It's a bit annoying but it doesn't destroy my workflow. See attached screenshots of the extrusion menu.
2.0.10440
MacOS 10.16.0
g-andresen
just tested > works fine
1. Please show the process in a screencast
2. Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
LaleveeJT
Thank you for your response. Funny enough, I had to restart for another issue ("error thrown by oss" when copying a file) and that seems to have fixed my extrusion issue. However I'm going to wait a minute to mark your response as resolved since I had the issue all of yesterday. I also have been intermittently experiencing an issue with extrusions where on a new extrude the values will be automatically populated from the last extrude I did.
I'm hesitant to reinstall the screen capture utility. I had to uninstall it recently because it caused an issue with my login credentials, causing me to have to log into Fusion every time I opened it.
It's hard for me to pin down exactly what is wrong, but overall Fusion seems to be acting strangely as of the update. I wish I could put it in better terms but it just feels different.
g-andresen
I have the same impression, but I can't verify it yet.
günther
