Extruded piece makes two pieces
ashjunkmail
ashjunkmail
Hello, I'm new to fusion and i'm trying to do the following:
1. I have two downloaded .stl's that I would like to combine into one.
2. I imported them as Mesh I aligned the smaller piece on the back side of the longer piece.
3. I extruded the rear piece 1mm longer on the left, and 1 mm longer on the right so that it extends the full length of the front piece
4. I moved (joined) the rear piece so that the front is flush with the front face of the front piece. (this is because the front piece has a fillet edge, and I think this is the easiest way to get rid of that edge and make a seamless piece?)
The Issue I'm having is that even though the rear piece was extruded (joined), it's still shows as 2 pieces, which makes it so I can't re-fillet the edges without getting this error:
TheCADWhisperer
@ashjunkmail
Can you File>Export your *.f3d or @*.f3z file to your local drive and then Attach it here to a Reply?
ashjunkmail
hello TheCadWhisperer, please see attached
ashjunkmail
 Hello, just checking to see if anyone has a minute to take a look and let me know what i'm doing wrong?
jhackney1972
I do not know why you have an External Assembly, the ProSlat Base Only component is not being used so I removed it.  The remain component can accept Fillets on the corners.  Model is attached.
John Hackney, Retired
ashjunkmail
Thanks for taking a look John, just so I understand what you did, was it just a combine tool that you used? I'll need to do the same thing for multiple different pieces, just learning very slowly.
ashjunkmail
Thank you John, that worked perfect
