Extrude from sketch changes profile extruded
threeleggedcat.shop
Message 1 of 8
threeleggedcat.shop
Any extrudes changes the profiles selected.  The extruded object is not valid.
Trying to clean up the sketch!  It is from a much larger project.  Other than starting over, how to fix?
thanks,
mark
Replies (7)
Message 2 of 8
jhackney1972
You post does not explain what your issue truly is.  From what I can read, you say the sketch gets messed up if you Extrude anything from it into the base body.  I did a Screencast to show it works as expected.  Your sketch is a little complex, I would separate it into multiple sketches but it is fully constrained.  Please clarify your issue with a Screencast of your own.
John Hackney, Retired
Message 3 of 8
jeff_strater
when you say "Any extrudes changes the profiles selected.", do you mean that a different profile is extruded on OK than you selected in the command?  I have seen cases like this before, but I do not seem to be able to reproduce it in your design.  If you can just grab a screenshot of the profile you are selecting that is not matched correctly on OK, I would be happy to look into that.
Jeff Strater
Engineering Director
Message 4 of 8
threeleggedcat.shop
Dang me, didn't see the "insert" button on the screencast.  But I get a error about invalid HTML when inserting.
The lower circle appears to be the culprit.
I was trying to clean this thing up!  Done when I was starting out.
thanks!
mark
Message 5 of 8
threeleggedcat.shop
I've enclosed two files, one with the selected profile (not in sketch mode) and the other the resulting extrusion.
After selecting the profile, I hit the extrude button, give it 5 mm depth and hit OK.  The resulting body lacks the lower circle.
I'll look into breaking the sketch into multiples.
thanks,
mark
Message 6 of 8
jhackney1972
This sketch was brought in from another component or body, not that it should make any difference.  I copied the sketch to a new file and the same extrusion issue happens.  You can Extrude it, but you have to do it separately.  I will leave this one to the Autodesk Pro's and follow it with great interest.
Edit: If you Trim it out to the final sketch, it works just fine.
Message 7 of 8
threeleggedcat.shop
I think it is haunted.
thanks for the responses.
mark
Message 8 of 8
jeff_strater
thanks for the info.  That is what we needed.  I created bug FUS-97062 for this.
Just FYI - I would probably make more of that sketch be construction geometry, but this still should work as is.
Jeff Strater
