Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I often need to export sketch geometry as DXF for use on a laser cutter.
The issue is that overlapping lines cause the cutter to trace its path twice.
My workflow to capture geometry is to select the surface in fusion and create a sketch.
I then project geometry onto the sketch
I then close the sketch and save to DXF
If it is a complex sketch it can take a very long time to select and delete every single overlapping line that the projection includes.
Is there a better way to do this?
Or is there a tool that I can use to automatically delete overlapping geometry?
