EXPORT an .STEP file into .STL
I have several .STEP files that I would like to export into a .STL file in order to use print them on my ROBO 3D printer and I can't seem to have the functionality to get it done , I need some help I attached here a STEP file I was trying to transform into STL
thanks
Max
jhackney1972
Take a look at the screencast for my process.  Please note, when you download it from the email link, you will see this in the screencast, the extension is missing.  Add ".stl" to the file you save.
John Hackney, Retired
jhackney1972
Once you have uploaded your STEP file, another method is to right click on the component in the Browser and select "Save As STL".  This is probably the easier method.
