Export 3mf error
Export 3mf error
addohm
Message 1 of 1
Export 3mf error
addohm
Hi, one practice I commonly use is exporting multiple objects as 3MF.  The reason for this is to have flush faces embedded into the main body of a project for later modification of those individual faces, also to make multiple versions of the same general project easier to put out.  This morning for some reason I've run into a problem where my slicer cannot recognize a specific body I've exported.  The only way I was able to "fix" it was going back into that project and combining all objects to make a single body, and using the "3d print" function rather than export.  Is there a specific thing I am missing that is causing this?  Again, I've done this for ages and never ran into import issues as far as I can remember.  It should also be noted that I can export as STEP, OBJ, and STL and it works.  It's only 3MF that's giving me this error.
(view in My Videos)
Replies (0)
