Evident bug or do I really do something wrong?
kristianY3VSG
kristianY3VSG
the screencast shows this situation:
  1. Fusion freshly started, new design, 2 sketches - vertical profile + horizontal path
  2. Extrude profile to object (end of left path line) => Patch1 (left)
  3. Sweep lower part of the right patch edge => Patch2
  4. Sweep upper part of the Patch1 edge along upper Patch2 edge:
    Preview OK, but after "OK" not the chosen profile is swept, but the middle horizontal edge.
This weird behavior occured in another, quite complicated design, where the sweep didn´t take just another edge, but all the primary patch edges, creating a rectangular "pipe". After experimenting with this quite a while (without any positive result), I created the "laboratory experiment" shown in the screencast. Sweeping all the right Patch1 edge gives the same result. In the "pipe" situation Edit feature -> unmark parts of the faulty profile by Ctrl-click crashed down Fusion. When I use Sweep instead of Extrude for Patch1, everything works fine.
As I could reproduce this succesfully from New design several times, it shouldn´t be a problem to verify this from scratch.
Screencast will be displayed here after you click Post.
534e90b7-9b12-4c26-86ba-8ec51b242c99
kristianY3VSG
Screencast Groundhog Day...  Still the same problems to insert SC succesfully 😞
TrippyLighting
Could you attach that lab experiment to your next post ?
kristianY3VSG
Hi @TrippyLighting
here you are... 🙂
