[Error] Using Split Body
middleofthebeach
Message 1 of 1
middleofthebeach
I am trying to measure a volume of a hole generated on a pipe using 3d scanner because the planned hole and the actual hole sizes are slightly different. The 3d scanned data is converted to stp file and imported in Fusion.
This is the procedure I was planning to do. This is based on the sled (https://forums.autodesk.com/t5/fusion-design-validate-document/measure-the-volume-of-a-hole/m-p/1290...).
1, Make a pipe body that have same curvature and diameter with the data.
2, Use Split Body for the pipe with the scanned data.
3, The portion that is cur out is the volume of the hole.
However, the Split Body does not work. Error message "No intersection between target(s) and split tool." occurs. Would you tell me how can I fix this problem?
I have attached the file. Please let me know if you need more information to solve the problem.
Replies (0)
