Measure the volume of a hole
- Mute
- Permalink
- Report
Hello I am new to Autodesk Fusion.
There is a hole generated on a pipe wall (upper figure of the attachment). I would like to measure the volume of the hole to investigate the small difference of the shape and size between the planned hole and the hole actually made. The hole is scanned by a 3D external laser and make a scanned image (middle figure of the attachment). The scanned image is converted to CAD such as STP & STL files. The hole shape is deviated.
Once the STL file is read by Fusion, a meshbody is created. I searched that if I close the hole inlet and outlet, I can measure the volume. So These are the steps what I did and plan to do:
1, I converted the hole wall (meshbody) to solid (Convert Mesh).
2, I Made the pipe outer and inner wall intersecting the hole (Sketch and Extrude).
3, I tried to get the pipe perimeters or surfaces crossing the hole using Project. But it did not work well. The surfaces will be the outlet and inlet area of the hole.
4, Once I get the surface, the outlet and inlet surfaces will be patched to the hole wall.
5, The region surrounded by the hole wall and the inlet and outlet surface will be the volume I want to calculate.
But I'm not sure these steps work well and stuck now. Would you please give me advice.
