Error: "There is unhandled intersecting tool data." when using Split Body
不适用
1,050 次查看
7 条回复
1 条消息(共 8 条)
不适用
I want to make a flap by making extruded bodies cut by the Right Horizontal Stabilizer and Flap Edge. I don't get why this error occurs. I could just use patch -> split face -> extrude, but this way I get to lose some details.
I will attach my f3d file.
P.S. there is a tiny gap between the upside loft and the downside loft, so you should include this in the splitting tool in order to cut the bodies.
0 个赞
1,051 次查看
7 条回复
回复 (7)
2 条消息(共 8 条)
jeff_strater
I'm not 100% sure what result you are trying to achieve, but the error is coming from the fact that you have a surface body and a solid body with overlapping faces.  What I suspect you were doing was choosing the surface body AND the solid body as splitting tools, so the error is exactly accurate - you are choosing two splitting tools that intersect.  If I turn off the surface body, and pick the two faces of the solid, you can split successfully:
Jeff Strater
Engineering Director
0 个赞
3 条消息(共 8 条)
不适用
What I actually wanted to do was exactly the opposite. I tried to split the bodies with the lofted surface. And when I tried to cut the bodies, I turned the surface bodies off.
0 个赞
4 条消息(共 8 条)
jeff_strater
like this?  If this is not what you are looking for, can you record a screencast showing what you are trying?
Jeff Strater
0 个赞
5 条消息(共 8 条)
不适用
Yeah that's right. But how come you did that so smooth? Is it because I didn't select it through the browser?
And I want to delete the outside piece of the body, but if I use delete on the outside piece, the split is deleted. How can I handle this?
0 个赞
6 条消息(共 8 条)
jeff_strater
sorry, @Anonymous - I probably was in a hurry, and did not explain what is going on there.  I'll try to do so here.
For the splitting tool in Split body, you can select a few different types of things:
  1. a face
  2. a workplane
  3. a body
If you select a face, the default setting is to extend the face so that it intersects with the body.  If you do that with this model, you get this:
turning off a few of the bodies, you can see that this extension causes the cutting tool to self-intersect:
while, selecting the body, either through the browser, or via Select Other (click and hold the left mouse button), selects the entire body, and does not extend it, and that is why you don't get that error message.
Jeff Strater
0 个赞
7 条消息(共 8 条)
不适用
@jeff_strater Thanks for the detailed explanation. But can't I delete the splitted body one by one? Selecting and deleting one makes Split Body canceled.
0 个赞
8 条消息(共 8 条)
jeff_strater
@Anonymous - you have to use Remove, not Delete.  For an in-depth discussion of why, see:  what-is-the-difference-between-delete-and-remove-a-component-or-body .  The confusion here is especially high with Split Body, unfortunately.
Jeff Strater
0 个赞
