Error installing and uninstalling Fusion360
Hello all,
A newbie that ran into trouble. I installed Fusion 360 about a week ago and it started up fine and such. 2 days ago, my computer had some start up issues and had to be restored to a prior backed up version (before installing Fusion360).
As of right now, I cannot run or open Fusion360. I have tried uninstalling but an error pops up stating:
Can not find script file: "C:\Users\Jonsie-Na\AppData\Local\Autodesk\webdeploy\met\uninstall.wsf."
When I try to reinstall with the downloaded, it detects that Fusion360 was installed already and give off an error
[WinError 2] The system cannot find the file specified.
I have gone though the the steps to see if this is a known issue and am trying this forum for some insight. Will also contact Autodesk support.
If anyone has any idea on what I can do, please let me know. Thanks in advance.
mohammed.aliTDPXK
Hello @Anonymous ,
I would recommend you to please try clean uninstall.
Please follow the link below.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-do-an-automatic-Clean-Uninstall-for-Autodesk-Fusion-360.html
Let me know if this helps, do like and accept solution if this solves your issue.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Thank you for the clean uninstall exe. It worked great and not is working again.
mohammed.aliTDPXK
Hello @Anonymous ,
Good to know that now Fusion is working for you 🙂
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
