Error: Failed to invoke 'onSection' in the post configuration. Error: Failed to execute configuration.
drmoon
drmoon
Regarding the error below, I've checked google and found a solution on this forum to check my WCS and that I'm using the most recent version of the post processor available through Fusion. I've uploaded a .f3d of the file and both of the post processors I tried (though I think they're the same).
Thanks in advance for any guidance.
Here's the error:
Information: Configuration: CENTROID
Information: Vendor: CENTROID
Information: Posting intermediate data to '/Users/****/Documents/CNC/1004.nc'
Error: Failed to post process. See below for details.
Start time: Thu Dec 29 01:17:29 2022
Post processor engine: 4.5917.0
Configuration path: /Users/****/Autodesk/Fusion 360 CAM/Posts/Centroid.cps
Include paths: /Users/****/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Fri Dec 9 18:19:41 2022
Output path: /Users/****/Documents/CNC/1004.nc
Checksum of intermediate NC data: 5fc71546d108da0d1721ab5aa371711a
Checksum of configuration: 418d5325c8064dec109c8b68e3092708
Vendor url: http://www.centroidcnc.com
Legal: Copyright (C) 2012-2022 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.15027
Error: Failed to invoke function 'onSection'.
Stop time: Thu Dec 29 01:17:29 2022
Post processing failed.
ltomuta
The two CPS files are identical.
When post processing with one of them, I got this error:
or the more detailed log output:
Error: Error: Work offset out of range.
Error at line: 1
Error in operation: 'Drill1'
Stack dump:
("Work offset out of range.")@:0
onSection()@C:/Users/Lucian/Downloads/Centroid.cps:594
Failed while processing onSection() for record 364.
Stop time: Thursday, December 29, 2022 8:58:14 AM
The work offset is indeed out or range. 55 means the 55th WCS while most machines probably support 6 (and eventually offer an extension mecanism for more). If you want to use G55 you should put offset 2, with offset 1 representing the G54...
So change that offset, create a NC Program for your setup and post process it. Done.
drmoon
Thank you! When looking at the file this morning, my WCS was actually set to "extended", I have no idea how it got set to "extended"... But all works now that I have WCS set back to "standard". (I do actually want G55 - I'm not sure if it's best practice, but I've been using that as a dry run with Z set above the actual part so the machine just "cuts" the air. And then I switch to G54 with Z set to the correct height.)
