Error: Failed to Boolean bodies together
fluteworks
fluteworks
I am trying to combign two different bodies. They definately overlap by a bunch, I confirmed this with Inspect>section analysis. I still get the error: inconsistent information in vertex and coedge attributes. Failed to Boolean bodies together. I have tried to stitch them together with no luck. I have tried to fix the mesh, but they aren't mesh anymore I guess? I am relatively new to F360 and this is the most complicated shape I have ever made, so I bet there is a hole in something somewhere, but I can't figure out how to find it.
The bodies I am trying to combine are in the screan shot.
TheCADWhisperer
@fluteworks
Ctrl b
fluteworks
Thanks! I thought that this spot overlapped, but that could be it! I will check it out, thank you!
fluteworks
It worked great, thank you so much! 2 hours of trying to find it before I posted down the drain, I bet you saw it in 2 seconds. Experience counts!! Thanks!!!
