Error: Failed coilfunction for knurling.
jorbakken
Message 1 of 16
jorbakken
Hi.
Happy new year everybody.
I`m trying to make a knurly pattern on a knob using the coil-function, but I get an error-message either by making the first half revolution or by mirroring it.
I get two different errormessages. Either:
or when I finally get a line and try to mirror it;
 I`ve tried to change patterns upwards and downwards. Making a new "target body" to see if I`ve done something wrong with the first object. Searching and speculating for answers. I`ve seen several videoes on youtube and it looks like this should be a easy thing to manage.
Does anyone know if I`m doing something completely wrong or if it`s a issue with the Coil-function?
Replies (15)
Message 2 of 16
g-andresen
try circular pattern
(view in My Videos)
günther
Message 3 of 16
jorbakken
Hi Günther.
My plan was to do like in the video: coil- mirror - circular pattern. The problem (like I showed in the screenshots), is the error messages I get both when I use the coil-function for cutting and the mirror-function for copying, wich means; I don`t have at base-pattern to transfer to a circular pattern. The problems occures before I get to the circular-patterns-function.
Message 4 of 16
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 5 of 16
jorbakken
File attached.
Message 6 of 16
g-andresen
Watch the screencast and play with the coil data, especially the coil height.
(view in My Videos)
Pay attention to warnings!
günther
Message 7 of 16
jorbakken
Thanks for taking the time making the video.
I tried doing it exactly like you did, but I still get the error-message:
As you can see the sketch is a bit shifted compared to the body, but like you, I just move the body in position when editing. I tried altering revolutions from 0,25 to 1 and section size 1 to 2, but it`s still the same error-message:
Message 8 of 16
jorbakken
..and I also experimented with the hight.
Message 9 of 16
g-andresen
1. follow the timeline in shared file
2. start a new design
3. service utility > Repair
günther
Message 10 of 16
jorbakken
Hi.
I tried the repair-function. That was a good suggestion, but it`s still the same:
Maybe I should try to delete Fusion and reinstall it? I don`t know. I`ve been going at this for weeks now... I just can`t wrap my mind around what the problem might be.
Message 11 of 16
g-andresen
1.Does my file contain the result shown in the screencast?
2. please share the latest version
günther
Message 12 of 16
jorbakken
Hi.
1. Yes
2.  Latest version below.
Message 13 of 16
g-andresen
In the screencast, I show you how to remove “distracting” areas and mirror profiles on a previously defined plane.
(view in My Videos)
günther
Message 14 of 16
jorbakken
Hi.
I managed to get the knurling stick to the cylinder when I did as in your latest screencast. I guess I made a mistake by doing something to the sketch for the knob in the original drawing, cause when I see turtorials it`s so plain and easy to get the knurling stick to the body. I`ve got me some knurling and that`s way better than getting nothing at all! Maybe I`ll just start all over again cause I struggle to see the mistake and repair it. I still got some error-messages, but now I got something to work with.
If I recreate the sketch for the body.... I will for sure mess up elements in the timeline, but if I can restore a correct sketch it might fall back in place? Do you know if that`s doable?
-Jørgen-
Message 15 of 16
g-andresen
In such cases, it is usually better to start from scratch.
That way you have a clean basis and can prevent “damaged” features from being the cause of the error.
günther
Message 16 of 16
jorbakken
Hi.
I started all over again and used some of the know-how you shared. The test on the picture doesn`t have the perfect surface, but as a knurling-test it came out just as I wanted it. A threaded crank-holder connected to a three-way gear.
Thank you for your help and patience!
-Jørgen-
Threaded crank-holder on a three-way-gear.Threaded crank-holder on a three-way-gear.
