Error capture position
oyvindTMNSU
oyvindTMNSU
Hi.
I recalculated my model and suddenly every single position capture and joint got a red error! Im so fed up of this behaviour in fusion 360! How do I fix it??
When I go to edit on the first failed position capture in the timeline, I can not move the component without getting a error saying "Error: Position calculation failed due to initialization error"
Then I'm stuck in a loop. Its not the first time this happens. What do I do? I don't want to replace all joints every time this happens
jeff_strater
@oyvindTMNSU - we are not going to be able to help you much unless you can share your model.  Sometimes the fixes to these models are easy, sometimes they are harder.  Rarely, if ever, should you have to replace all the joints.  Usually there is one joint that causes the problem.  I tend to start back from the last joint added -  suppress it and see if the error goes away, the work backwards.  Another approach is the opposite - start from the beginning, and work forward until you see the error.
I like to use Compute All as a kind of crude design checker - run it every once in a while as you go to make sure things are OK, then save, and go on.
Jeff Strater
Engineering Director
