Erase lines
Erase lines
memo2022
Message 1 of 56
Erase lines
memo2022
Hi guys, I connected two parts but i found these line. How to erase these lines showing down? please make a video for the solution. I attached a picture and the file.
Replies (55)
Message 2 of 56
g-andresen
Extrude inner profile to outer surface
(view in My Videos)
günther
Message 3 of 56
TheCADWhisperer
Message 4 of 56
memo2022
I got the lid right but when i went to the chamber it did not work please see the video
Message 5 of 56
g-andresen
What do you want to show?
On your "shaky video" I can only recognize that it is a different file than lid.f3d from #1.
günther
Message 6 of 56
memo2022
I attached the file. I want to close those lines on the surface please.
Message 7 of 56
TheCADWhisperer
@memo2022
OK, let's get started.
Sketch a rectangle below the Origin...
Attach your new file here for next step.
Message 8 of 56
abinessa
CAn you just make a video on how to erase the lines as you did in the lid please. I attached the file again. Just show in the video please.
Message 9 of 56
TheCADWhisperer
@abinessa
The original file is modeled all wrong (see just one example in image below), so it will be best to start over from scratch...
@abinessa
The designer @memo2022 seems to be having trouble sketching a dimensioned rectangle.
Message 10 of 56
memo2022
I fixed that please see the attachement. Last question how to place the object in the centre. Why I have to move the object to the centre to make the sktech and the measurement wont be accurate can you demonstrate in with this design how to place the object in the centre automatically like solidwork. Thanks
Message 11 of 56
TrippyLighting
I propose that your skills in SolidWorks also aren’t up to snuff. As such my recommendation would be to follow @TheCADWhisperer ’s suggestions step by step. Chances are that you’ll actually learn how to model, rather than just hack through stuff 😉
Message 12 of 56
memo2022
can you make a video on how to place the object in the centre automatically from what i sent. thanks
Message 13 of 56
TheCADWhisperer
@memo2022
OK, it turns out that I am a Certified SolidWorks Professional (CSWP) since 2007 and have taught many other CSWP and CSWE.
So let's get started...
Sketch a Center Rectangle at the Origin as shown below...
Attach your *.f3d file here for next step.
Message 14 of 56
memo2022
done
Message 15 of 56
memo2022
done
Message 16 of 56
TheCADWhisperer
@memo2022
Because it took all day to get this far - we will have to take baby steps at first.
Add these two dimensions ...
Notice that the sketch changes color (just like in SolidWorks).
Attach the file here for next step. (This will only take 15 minutes from start to finish.)
Message 17 of 56
memo2022
done
Message 18 of 56
TheCADWhisperer
@memo2022
Now sketch these circles as shown below (BTW - there is an easier way to do  this in Fusion 360 and in SolidWorks but you didn't seem to want to follow my instructions for the easy way, so we will do it the hard way.)
Message 19 of 56
memo2022
done
Message 20 of 56
TheCADWhisperer
@memo2022
I can't see your dimensions.
Either spread them out or better yet, Attach your file here.
