- Mute
- Permalink
- Report
As trivial as an issue this may seem, this most recent update has had one particularly noticeable and irksome change that I don't think is intentional.
I generally work in Fusion with the "Dark Sky" environment as with my large screen and dark room, anything else is blinding. This was the first thing I did when I first downloaded Fusion. Now, for whatever reason since updating to the latest version today, it resets it. I need to reset the environment to Dark Sky every time I open it. It is not difficult, but it is somewhat annoying to encounter my entire room being lit up by a blinding white screen on start up now when I did not used to have to do this every time. Is there a reason this no longer operates as the most recent environment used like it used to? I found nothing related in the change log.
Out of frustration I have tried making a script to do it on startup but the API does not support any of it.
