Entering a user parameter changes to constant value every time.
marcus.gerrett
marcus.gerrett
Entering a user parameter as a value no longer links to the user parameter, it reads the value and sets it as a constant. You can then edit the value a second time with the user parameter, at which point it will link. This is a 2x increase in work to end up with the same results from before the update.
Given the amount of bugs that get pushed with every update, is there a way to disable automatic updates or do we just have to live with a constantly broken product?
Version: 2.0.18719 (arm64 Mac).
jhackney1972
It must be a MAC problem only, I am using Windows 10 and it works just fine.
John Hackney, Retired
marcus.gerrett
Thanks for checking on that. I've also verified that the bug affects projects created before the most recent update, where user parameters were previously working as expected.
