Enable prompt for description when saving
Waitangi
Waitangi
With the change to CE Hub the prompt window for adding a version or save description is gone. While some users wished for it to disappear or to have the option to disable it (Disable "Save Version Description" Prompt), I used it frequently to track changes, especially when collaborating with other colleges.
Now after each save I always have to open the history window (e.g. from history symbol in the detailed view of the file in the data panel) and then go to the latest save and change manually the "User Saved" to my description that I need.
This is very unhandy and it would be great to have a short cut for saving with description or the option to enable a prompt window when saving.
lauri_barnhart
Hi @Waitangi,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Let us know how we did on Trustpilot.
Waitangi
Hello @lauri_barnhart,
this issue still exist. If you can provide me with a faster and more effective way than what I have described before, I would highly appreciate it! This takes so long as also loading the History window takes ages!
It would be great if it can be brought back at least as an option to enable it. It also got discussed and requested by others in connection with the versioning issue:
- Bring back the Version Number
- Create Version is not supported for this design
RajkumarIlanchelian
@Waitangi This topic is being discussed and our product management is following this thread - https://forums.autodesk.com/t5/fusion-support-forum/bring-back-the-version-number/m-p/14090175/highl...
If there is any update it will be posted to that thread
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ChrisHeerschap
I'd love to know why Autodesk keeps dropping these "improvements" which break how it has worked (very nicely) for years without giving the option to opt out.
engineeringNPFNM
Autodesk: Please add user preference that allows users to show/hide v-numbers in all the UI elements and file export dialogs that used to show v-numbers. Please add user preference that selects whether or not to popup the "Version Description" dialog box when the user hits save. These two changes would solve so many problems!
Some users may not have liked seeing the v-numbers, but some of us have been relying on them in our workflows.
roblesY77E3
Community Visitor
Community Visitor
Adding my voice here about one specific change that came with the CE hub migration: the Save dialog.
I often try out changes that I would only save if they worked out in the end. The Save dialog used to act as a safety step: if I clicked Save by mistake, I could just cancel. Now a single misclick saves right away. Recently I saved by accident in the middle of a test, had to go back to the previous version and start the test over.
My team shares the same projects, and the previous one-at-a-time workflow always worked well for us. We never needed simultaneous editing, but we did rely on the save dialog every day.
Please bring the dialog back, or at least add a preference to turn on a save confirmation.
