Emboss tool problem
Emboss tool problem
s189436UAN9B
Message 1 of 8
Emboss tool problem
s189436UAN9B
When using the Emboss tool in Fusion 360 on a spherical body, I get the following error when trying to deboss a pattern:
Error:
Deboss
Cannot create emboss feature. Adjust sketch profiles, faces, emboss depth, effect, or alignment options.
I’ve tried several approaches, but none of them seem to work. Is it even possible to deboss such a pattern on a spherical body? I’ve read that this tool doesn’t work with overly complex geometries.
Could you please advise me on what I need to do? Thanks!
Replies (7)
Message 2 of 8
Warmingup1953
Message 3 of 8
s189436UAN9B
That won't work unfortunately. When you try multiple emboss, it won't align and then it'll overlap, not allowing for the whole pattern to be debossed.
Is there perhaps any other way to get it to work? Thanks!
Message 4 of 8
marckodose3195
Community Visitor
Community Visitor
Message 5 of 8
TheCADWhisperer
@s189436UAN9B
The body is not spherical.
Rather than non-uniform scale of a sphere - I would have Revolved a sketch profile.
How will the part be manufactured (that determines how I would do the pattern)?
Will in ONLY be 3D printed, or will you be mass producing molded part?
Message 6 of 8
s189436UAN9B
Sorry, my mistake, it’s not spherical. However, I found a workaround. I added a frame around my pattern, so instead of debossing many individual faces (which Fusion struggles with), I embossed a very thin layer of the pattern as a single face.
After that, I deleted the pattern from the model and offset the outer shell by the thickness of the embossed layer, which made the surface smooth. It’s not perfect, but it works.
Message 7 of 8
TheCADWhisperer
@s189436UAN9B
This sounds like an interesting solution.
Can you Attach it here - I would like to experiment with this idea.
Message 8 of 8
s189436UAN9B
Yeah, as long as it works, I am not complaining. Here you go.
