Emboss Feature creates strange geometry
dave_gryp
Observer Observer
dave_gryp
Observer
Observer
I am trying to emboss simple profile shapes created with the control point spline tool. Some shapes are fine but others produce weird faces and geometry on the embossed body. I would love to know how to avoid this or fix it. I cant replicate the effect reliably so I don't know where I am going wrong.
I have added 3 pics. One is the sketch used, the second you can see that the emboss looks fuzzy around the edge. The third I have used the offset face command to pull the emboss forward to show how messy it is.
It happens a lot!
Any help would be greatly appreciated!
Many Thanks,
Dave
g-andresen
1. no pics attached
2. Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
dave_gryp
Observer
Observer
Hopefully attached this time
jhackney1972
for me, your only problem is that you are not Embossing deep enough.  Model with a deeper Emboss is attached.
John Hackney, Retired
dave_gryp
Observer
Observer
Hi John,
Thanks for the reply. The object I am making is to be 3D printed. It will have an LED light placed inside which shines through. The emboss depths are important for the intensity of the light and cannot be not be any deeper. The depth I need is 2.2mm leaving 0.8mm wall thickness. Is this something that cannot be done with the emboss feature at the moment?
Many Thanks,
Dave.
jhackney1972
The Emboss issue is being caused by a very bad Spline Curvature.  I have use the Mesh Section Sketch to remove this problem and then completed the Emboss.  I only did the heart shape, you can repeat the process for the other sketch.  Your model is attached.  If you need help interpreting what I did please let me know DIRECTLY.
Since you are new to the Forum, I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
jhackney1972
Did my last model solve your issue?  If so, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
