Emboss/Deboss on surface that curves in two directions
I have heard that the ability to use the emboss feature on a surface that curves in two directions is in development? Currently, I am unable to use the emboss feature as I would hope to. After not being able to select the surface, I searched the forum and it seems this issue was raised back in August 2020. Would it be possible to update me on when the ability to select a surface that curves in two directions to emboss might be available?
g-andresen
While you are waiting for the option, you can take a look at this.
günther
Thank you for the quick reply. The alternative suggestion video is appreciated. It's not so easy to follow but it's great that someone figured out a way to do it. Hopefully Fusion will simplify the process.
