Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
ELECTRODE DESIGN TOOL
GRAEMESUQ2Y
Message 1 of 17
GRAEMESUQ2Y
Hi
Can someone tell me if there is any prospect of an electrode extraction or design tool planned to be developed for Fusion 360
Thanks in advance
Graeme
Replies (16)
Message 2 of 17
paul.clauss
Hi @GRAEMESUQ2Y
Thanks for posting! Fusion 360 does not currently include any tools for electrode extraction or design, or wire EDM CAM operations. This has been presented at the Fusion 360 Ideastation at this link - please give it a vote if you'd like to see this option included in Fusion.
You could also consider looking into Autodesk Electrode. While I have no experience with Electrode, you could contact their team through the Contact Us page on the link to learn more about it.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Message 3 of 17
ryan60x
I make electrodes with fusion 360 on a regular basis. It works well with the the cam feature of making stock negative for the over cut. Fusion even says in the discription of stock to leave, negative stock is used for electrodes. If you need more information I can help.
Message 4 of 17
ryan60x
The first step is to create a sketch of the outline of your electrode over the top of the area to burn. Next, extrude to cover the area of the burn fully. I also model the system 3r holder on top of the electrode. Use the split body command this will give you a reverse image. To Machine the electrode I use the negative stock option in my toolpath so let's say -.015 axial and radial that is your overcut. You may also have to use the surface modeling feature to get your electrode the way you want. A word of caution sometimes you have to alter your negative stock depending on how the surface machines in the simulation using the compare feature. Once you get it figured out it works well.
Message 5 of 17
jlarkin
Hi looking to create an electrode from this model for a test with Orbiting I tried to mirror the face but it only reversed the letter not the form will Fusion do this
Message 6 of 17
ryan60x
This may take some surface modeling, or try using boundary fill to extract the electrode. It can be done.
Message 7 of 17
TheCADWhisperer
@jlarkin
Message 8 of 17
jlarkin
Thank you for any information you can provide
Message 9 of 17
jlarkin
any word on this?
Message 10 of 17
TheCADWhisperer
@jlarkin
I guess I didn't understand the problem description.
It looked like to me that you already had an electrode designed in the assembly that you Attached.
Message 11 of 17
HughesTooling
Do you want something like this?
I projected the outer edge of the tip into a sketch, extrude then combine cut. See attached file.
Mark Hughes
Owner, Hughes Tooling
Message 12 of 17
jlarkin
the part is what I sent I need the entire face form reversed on to an electrode so I can create the cut path for a Mill
Message 13 of 17
jlarkin
also what are you using Fusion 360 or another program
Message 14 of 17
jlarkin
this is what the finished insert looks like
Message 15 of 17
HughesTooling
@jlarkin Did you look at the file I attached to my post? It should be what you're asking for.
Mark Hughes
Message 16 of 17
jlarkin
That profile is the same as the punch see pic above that is what the electrode should look like
Message 17 of 17
jlarkin
sorry for any confusion this is what I was looking to get
