Editing *.ipt files in Fusion 360
radhika.kataria
Message 1 of 9
radhika.kataria
I have an old file from someone in a *.ipt format. I want to edit some dimensions in the drawing.
But I am not able to edit it in Fusion 360 probably because the drawing is a body and not a sketch.
Is there a way to do this directly in Fusion or do I first need to convert the file into a different format
or make a sketch from the body?
I have attached the file for reference.
Thank you
Replies (8)
Message 2 of 9
hamid.sh.
File is not attached. You should wait until it gets uploaded and then click Post.
Hamid
Message 3 of 9
dsouzasujay
Hi @radhika.kataria
You can use AnyCAD workflow to edit .ipt file
For single .pt file you can use Fusion web and Fusion 360 Application.
For assembly, You need to install Desktop connector.
if you can share the dataset and point out the modification, then will be able to help you.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 4 of 9
radhika.kataria
Thank you for this information.
I have uploaded the file both in the *.ipt and *.f3d formats.
I hope they are posted this time.
I want to change the diameter of the inner cylinder to 37.5 mm from 37 mm.
Message 5 of 9
radhika.kataria
Thank you for letting me know.
Message 6 of 9
hamid.sh.
For any Solid body (NOT mesh) whether created natively by Fusion or imported you can use Solid > Modify > Press Pull to edit current hole faces:
Edit: you can use Offset Type as Modify Existing Feature, but I prefer New Offset which is recorded in timeline (if you first Capture Design History from right click menu on the root component in the browser).
Hamid
Message 7 of 9
dsouzasujay
Hi @radhika.kataria
To change the hole dia, its simple and straight forward.
No nee of AnyCAD workflow.
There are other ways to change hole dia, but the below one is easiest
Please follow this video: https://autode.sk/38YJVaY
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 8 of 9
radhika.kataria
Got it. Thanks a lot.
Message 9 of 9
radhika.kataria
Works perfectly. Thanks a lot.
