Edit sketch locks up the image regardless of the design tab that can be selected, triad is dead.
Since updating to the 2026 Fusion, I offered my daughter that I would fix her design to split it up into separate designs and get out of the hybrid mode as her design is too big to manipulate effectively, to many eyeballs to switch on /off, and I wanted ot show here how cad is really meant to work designs and assemblies are different files! After doing that I started to tackle the global parameters (which honestly is terrible and sorry to say shameful, do as inventor did even a decade ago, it's all per project).
Have not made any progress on this front because I can't edit a sketch without the fusion SW freezing the 3D object and a blue version of the sketch, the tirade on the top right corner stops work, no little house next to it shows up, and from then on all that works is finish sketch and hopping to another design tab, but they are useless as the frozen window remains to prevent another design from showing up or allowing any sketch edits.
Restarting fusion ONLY works till the first edit sketch of any part, even the simplest part results in the freeze.
reboot, uninstalling, reboot and reinstalling fusion - same issue - tried days of variations, close to a week on figuring out how to get fusion to TRULY uninstall, it leaves stuff everywhere, resorted to manually deleting autodesk and fusion folders everywhere after the unistall was ""complete"", finally removing registry entries I got it to reinstall and work, but then after a few hours of messing around with the parameters making them have the _Ref (fyi importing CSV with the _ref postfix does not work even thought its in the derived file of each design, it's all manual for ~115 parameters per file, the delete select all user params and trash them delete too many 😞 ) to make them global - but I digress, the key point is the **** problem returned!
The files sketches are editable on another computer and this last time it died while trying to edit a design that had not caused the issue, so I don't think it our files. I also don't believe it our computer as it works very well on many other activities outside of fusion.
Have no idea how permanently fix this as the reg edit solution with reinstallation is not practical - sorry to vent but am burned out on this problem
