DXF import and sketch manipulation issue
dmitriy
Message 1 of 8
dmitriy
See attached screencast
Import DXF logo and try to manipulate. It goes haywire. I understand its unconstrained, but perhaps it should still move in unison without issue?
Thank you
http://autode.sk/2EC3Hs9
Replies (7)
Message 2 of 8
masa.minohara
Hi @dmitriy,
Thank you for posting! I'd like to take a closer look at it, could attach the DXF file here?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 8
dmitriy
Attached
Let me know how it goes
Message 4 of 8
masa.minohara
Hi @dmitriy,
Thank you for sharing the file with me! This DXF file looks a bit different from the one in your screencast. Are you having the same issue with this one as well?
I tested with this file but could not reproduce the issue. What happens if you insert the DXF to another design? Do you still see the issue?
Masanobu Minohara
Message 5 of 8
dmitriy
I think I attached wrong file
Try this one
Message 6 of 8
masa.minohara
Hi @dmitriy
Thank you for sharing the file! I was able to reproduce the issue. I think I need to reach out to the development to find out what is causing the issue.
Also, I was just curious why the issue occurs only in the second file. What program did you use to create these DXF files? Did you use different programs or use the same program but different commands?
Masanobu Minohara
Message 7 of 8
dmitriy
Glad you can recreate it!
As far as file creation - I cannot recall. It may most likeley have been in Solidworks and then exported as DXF. I doubt I did it in Illustrator.
The other variable could be font? But I dont know why two DXFs would have different outcomes like that, Id think they get standardized somehow in the process of becoming a DXF and lines are just lines..
Message 8 of 8
masa.minohara
Hi @dmitriy,
Thank you for your response! I have logged this issue with the development team for further investigation. (the ticket ID is FUS-38309 just for your reference)
I'll post an update as soon as I have more information to share. Thank you for reporting this!
Masanobu Minohara
