- Mute
- Permalink
- Report
I've had this issue a couple of times, where we are trying to rescue old data from a DWG file and when the file is uploaded to Fusion via a web browser, I can clearly see both the 2D and the 3D data. Regardless of what I try, I can't seem to get that same data to open in Fusion 360. I've downloaded, used the Desktop Connector, etc., but whatever I do, I can't seem to get Fusion 360 to open what I can see when viewed in the web browser. Is this a limitation of Fusion 360 or is it possible that I'm just not going about it in the right way. I would assume that if I can see it via Fusion in a browser that the data is capable of being converted to something that Fusion 360 should also be able to see and use. Any help would be appreciated. Here is a link to the screencast that shows what is in the file when viewed on the web, but nothing is coming through in Fusion 360.
