In the last few weeks I have output DWG files for 11 items connected to having sheet metal parts for a personal project laser cut. I should say I am very new to this, having last used CAD 30 years ago, and am finding the learning curve very steep. So take it easy on me eh?.
The DWGs, one as a sigle item, one with 3 items in the design and one with 7, ( inserted into one design from the individual designs), went to one company who couldnt open them ( current output 2013 file). I resent after opening in and saving from DWG Trueview as 2004 files, with slightly more success. They managed to part open and modify 3. After much trouble, i decided to try another laser company, who use Sigma nest. They could not open any of my DWGs in 2013 as output from Fusion, so I did the DWg trueview again as all 2004, 2007, and 2010 files, again they had issues, most wouldnt open, although a couple did as drawings showing dimension lines only and no object or body. I tried to open all files sent them in Librecad to see what I would get, and a free DWG viewer, as all opened fine in DWG Trueview, not a single item opened ok in these two other programs?
The Laser company asked if I would send as DXF as having so much trouble, so I sent 11 seperate DXF's, of which 4 failed again, although 3 opened ok in Librecad, of those 4, 3 had lines drawn with the conic curve function, and the guy at the company had said that might be an issue. I have now redone the one of the 4 which failed in Libre and the DXF, and that opened ok in Libre, leaving 3 failed DXF, which they are going to redraw themselves from a copy of my sketch dimensions.
After much hassle and several late nights I would like to get to the bottom of what is going wrong, as I cannot see why so much failing, are Fusion Files only useable from Autodesk products? , as if so it means everyone should be having the same issues at Laser companies as I have with two of them? How do I correct, in case its me doing something in error? In case my email is needed it's billyread@btinternet.com
many thanks
Bill Read
