DWG and DXF output for laser cutting sheet
In the last few weeks I have output DWG files for 11 items connected to having sheet metal parts for a personal project laser cut. I should say I am very new to this, having last used CAD 30 years ago, and am finding the learning curve very steep. So take it easy on me eh?.
The DWGs, one as a sigle item, one with 3 items in the design  and one with 7, ( inserted into one design from the individual designs),  went to one company who couldnt open them ( current output 2013 file). I resent after opening in and saving from DWG Trueview as 2004 files, with slightly more success.  They managed to part open and modify 3. After much trouble, i decided to try another laser company, who use Sigma nest. They could not open any of my DWGs in 2013 as output from Fusion, so I did the DWg trueview again as all 2004, 2007, and 2010 files,  again they had issues, most wouldnt open, although a couple did as drawings showing dimension lines only and no object or body.  I tried to open all files sent them in Librecad to see what I would get, and a free DWG viewer, as all opened fine in DWG Trueview, not a single item opened ok in these two other programs?
The Laser company asked if I would send as DXF as having so much trouble, so I sent 11 seperate DXF's, of which 4 failed again, although 3 opened ok in Librecad, of those 4,  3 had lines drawn with the conic curve function, and the guy at the company had said that might be an issue. I have now redone the one of the 4 which failed in Libre and the DXF, and that opened ok in Libre, leaving 3 failed DXF, which they are going to redraw themselves from a copy of my sketch dimensions.
After much hassle and several late nights I would like to get to the bottom of what is going wrong, as I cannot see why so much failing, are Fusion Files only useable from Autodesk products? , as if so it means everyone should be having the same issues at Laser companies as I have with two of them? How do I correct, in case its me doing something in error?  In case my email is needed it's billyread@btinternet.com
many thanks
Bill Read
HughesTooling
This is a long time problem and there are many post on it. The short answer is the DWGs are in a format only AutoCAD can open. Some people have had luck saving to an older version from DWG Trueview and opening in Draftsight, can't remember the version 2010 I think. If you have AutoCad you need to use EXPORTLAYOUT to extract the drawing view.
Mark
Mark Hughes
Owner, Hughes Tooling
ryan.bales
Autodesk Support
Autodesk Support
This is certainly something that comes up quite often. The Drawings Team is working on a DWG export with exploded model space views but its a ways out.
If you are using Sheet Metal - why not use Derive with the flat patterns? you can then create a sketch and project the flat patterns, export to DXF.
Ryan Bales
Fusion 360 Product Support
