Duplicated with rectangular pattern. Looks same size but measurement shown otherwise.
0364427
Message 1 of 10
0364427
Hello.
I'm new to FUSION.
I'm having issue with the measurement by using the rectangular pattern function.
After duplicate, the gap that measured was not accurate. Visually seems correct.
Hopefully someone e can advise me on this
Dean
Replies (9)
Message 2 of 10
jhackney1972
Please attach your file for analysis.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 10
jeff_strater
you'll have to share the design to get help.  Export as a "Fusion Archive (F3D)" and attach it to a post here.  Thanks
Jeff Strater
Engineering Director
Message 4 of 10
0364427
Hi John.
I had recreate a new file with keying in correct measurement.
However the measurement tools was off.
Kindly find attachment for the working file.
Dean
Message 5 of 10
0364427
Hello Jeff.
Here you go.
The measurement was off.
Creating the rectangular pattern measurement was in correct too.
Please advise.
Dean
Message 6 of 10
davebYYPCU
What were you selecting?  I can't replicate it, and the only error I get is a depth error,
I am unable to select the centre point of a cylinder with the Measure Tool under my config. (Windows 10)
Might help....
Message 7 of 10
KristianLaholm
You have a square side length of 31, the circle center is places 7,5 from left side and a rectangular pattern with spacing 14,5.
This will place the circle center 9 from right side (31 - 7,5 - 14,5 = 9).
Your design inputs are not symmetric.
If the dimensions from circle to edge and from circle to circle are important you have to drive the side length from those dimensions.
Sketch with driven dimensions from your design.
Message 8 of 10
g-andresen
your spacing is wrong > create a parameter for spacing
günther
Message 9 of 10
0364427
Thank you for founding this. I never knew it will auto select the top face when I measure it from the top.
Is there anyway to disable this?
Message 10 of 10
0364427
Thank you for the clarification and details. It was my own error in calculating the wrong dimension, and I was not aware that the measurement tool was measuring the body with the extrude pillar top face.
