Duplicate conflicting joints when updating a reference design
feoranis
Message 1 of 8
feoranis
I have an issue with a derived design where if I update it to the latest version, the joints from the previous version are not removed, all joints end up getting duplicated. If a joint position was updated in the new version, this causes a conflict with the old joints when I update the component.
I am not sure if this is an issue caused by me somehow, an issue specific to my fusion installation, or a bug that can be reproduced.
Replies (7)
Message 2 of 8
feoranis
It seems like the video attachment didn't get processed for whatever reason.
Message 3 of 8
feoranis
For some reason the forum won't process the video file, so I had to upload elsewhere.
https://youtu.be/O3A-c7enNx4
Message 4 of 8
jhackney1972
The video you posted is showing twice, it takes a few minutes to generate.  I tried to replicate your issue but could not.  Take a look at my video and see if I did something different than you.
John Hackney, Retired
Message 5 of 8
feoranis
I've noticed that it took until I edited a joint position (specifically Rigid 25) until the issue started appearing. It also does not happen again in a new design, as you tried. I guess for now my options are to delete the existing one and re-derive it, and manually fix whatever it breaks in the process.
Message 6 of 8
sibashis.bishi
Hi @feoranis
Thank you for reporting this. We have found the reproducible steps for this issue. Taking a look into this issue.
Sibashis Bishi
Senior Software Engineer
Autodesk, Inc.
Message 7 of 8
swapnil.hamdapureDDSVZ
Hi @feoranis , The issue is fixed in the latest update - build 2603.1.52. Please let me know if still facing any issue. Thanks.
Message 8 of 8
Closed-Loop-Bot
We're happy to report this issue has been resolved. Update Fusion to the most recent version to apply the fix. If this update resolved your issue, feel free to click the "Accept Solution" button to help other community members find the answer more easily. If the issue persists after updating, don't hesitate to reach out to us by replying to this thread. We're here to help! Let us know if you need any further assistance!
