Duplicate conflicting joints when updating a reference design
feoranis
feoranis
I have an issue with a derived design where if I update it to the latest version, the joints from the previous version are not removed, all joints end up getting duplicated. If a joint position was updated in the new version, this causes a conflict with the old joints when I update the component.
I am not sure if this is an issue caused by me somehow, an issue specific to my fusion installation, or a bug that can be reproduced.
feoranis
It seems like the video attachment didn't get processed for whatever reason.
feoranis
For some reason the forum won't process the video file, so I had to upload elsewhere.
https://youtu.be/O3A-c7enNx4
jhackney1972
The video you posted is showing twice, it takes a few minutes to generate.  I tried to replicate your issue but could not.  Take a look at my video and see if I did something different than you.
John Hackney, Retired
feoranis
I've noticed that it took until I edited a joint position (specifically Rigid 25) until the issue started appearing. It also does not happen again in a new design, as you tried. I guess for now my options are to delete the existing one and re-derive it, and manually fix whatever it breaks in the process.
sibashis.bishi
Hi @feoranis
Thank you for reporting this. We have found the reproducible steps for this issue. Taking a look into this issue.
Sibashis Bishi
Senior Software Engineer
Autodesk, Inc.
swapnil.hamdapureDDSVZ
Hi @feoranis , The issue is fixed in the latest update - build 2603.1.52. Please let me know if still facing any issue. Thanks.
