Drop down menu bug
Drop down menu bug
mac_ito
Message 1 of 23
Drop down menu bug
mac_ito
When you click on the menu it appears briefly, unless you deploy the data panel
(view in My Videos)
Replies (22)
Message 2 of 23
mac_ito
problem appeared with the release: V.2.0.14567
Message 3 of 23
sutherland-
Hi @mac_ito
Are you running dual monitor setup?
Try resetting the user interface to the default layout and see if it resolves the issue.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 4 of 23
mac_ito
Hi, thanks for you tips but it does not change anything, yes I have two monitors
Message 5 of 23
sutherland-
Is your F360 up to date?
For now, an easy way to resolve this is to:
  1. Dock the ribbon at the bottom of the screen
  2. Move it back and dock it at the top.
Best regards,
Level  sutherland-
Member
Message 6 of 23
mac_ito
yes release 2.0.14569. problem already present with 2.0.14567
Message 7 of 23
sutherland-
Did this help?
Best regards,
Level  sutherland-
Member
Message 8 of 23
mac_ito
not tried, however reset to default layout may finally have an effect. to be continued
Message 9 of 23
sutherland-
So my first post about "Try resetting the user interface to the default layout and see if it resolves the issue." fixed the issue? 🙂
Best regards,
Level  sutherland-
Member
Message 10 of 23
mac_ito
it seems so, because after restarting f360 the problem is no longer present. I will check if the problem reappears or not after restarting the computer.
Message 11 of 23
sutherland-
If it re-occurs, please try to contact support. 🙂
Best regards,
Level  sutherland-
Member
Message 12 of 23
mac_ito
problem still present
Message 13 of 23
FrodoLoggins
Same for me on M1, though it has gotten much better with the last update.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 14 of 23
doreen_holley
same problem with i9 chipset
12.6.3
Message 15 of 23
doreen_holley
Restarting did not help the problem
Message 16 of 23
FrodoLoggins
Just clicked the workspace switcher menu button probably 50 times in a row kept disappearing.
I feel like basic functionality like "clicking on a drop down menu" or "deleting a file" or "not having the browser disappear and block the rest of my screen's content" or "dimensioning a line segment without it disappearing out of view" or "rotating the camera with a trackpad" or "selecting the thing directly under my mouse pointer" should work. Like all the time.
Also is the blend preview toolpath getting any attention or is that being ironed out by someone on the Star Citizen development team? It's been in preview for at least half a decade lol.
Message 17 of 23
falcon.atticus
Community Visitor
Community Visitor
I'm having this issue, only with a bluetooth mouse, and only on the "Create" and "New" (little page icon), all other drop down menus appear fine. The track pad on my Mac (m1) doesn't have the issue, only when using a mouse.
My quick workaround is to click on the "Modify" menu and then slide over to the create menu, which then drops down without having to click again.
Message 18 of 23
FrodoLoggins
Resetting the user interface to the default layout did not resolve this.
If by "ribbon" you mean the browser tree; re-docking it didn't resolve this either.
That's actually buggy as well because: It'll just go missing/off screen:
Or it'll end up in two pieces:
Or dragging the ribbon with my mouse pointer will work and the menu will get moved around but my mouse pointer will be 2 inches away nowhere near the browser tree:
https://youtube.com/shorts/j9ZYrklQuVY?feature=share
Is there a solution to this? Pretty annoying having to click a drop down menu 3-20 times before it finally sticks 50 times a day.
Issue occurs both with mouse and trackpad.
EDIT: OMG I've been dealing with this for a year...
Message 19 of 23
FrodoLoggins
@mac_ito Doesn't look like this is resolved for either of us. I think if the post by @sutherland- was unchecked as solved that might help us out.
Message 20 of 23
doreen_holley
Drop down just doesn’t work (using trackpad)
