Drawing Workspace Lines not showing up
thegunpsy
thegunpsy
I think I have a bug. The lines are not showing up in the drawing workspace. Even if I sketch a dimension, the line wont show and the measurement numbers are barely visible. I am running the most current version of F360. This was not occurring prior to the update.
ClintBrown3D
Hi @thegunpsy
This issue is caused by a recent Windows update that has rolled back certain Graphics drivers, it appears that AMD cards are most affected. The good news is that most of the reported cases have been resolved by updating the graphics driver.
If you update your graphics driver directly from the manufacturer's website (NOT via Windows update), it should resolve the issue. Fusion has a built-in tool that will identify your graphics card, see below. Clicking on "Check for GPU driver update" will take you to the manufacturers' website. From here you can find and install the correct driver.
If you are still having issues, see this article:
https://clintbrown.co.uk/updating-graphics-setting-for-fusion-360-customers-experiencing-fuzzy-or-mi...
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
thegunpsy
Awesome, I will give this a try in a bit. I will let you know how it works out.
thegunpsy
This fixed worked great! Thank you.
ClintBrown3D
Excellent, glad you are back up and running!
Clint Brown
